Just did tune up, now its misfiring
so i removed the spyder injection today, the area was filled with grease like stuff not sure how & why.
I believe 2 or 3 injectors seem to be clogged and the lower gasket wass ripped which is probably the reason why, my coolant would leak a bit about 6 months ago.
hopefully i can find a used spyder injection kit and install tomorrow.
just thought an update would be great for people that might have the same problem as i did.
I purchased the spyder injection from "O Rileys Autoparts" and it still does the samething...
I checked the coil with dmm & it is to spec.
Could the igniter cause the problem im having?
any ideas on what can cause a missfire, btw can a clogged cadylatic converter cause this? a friend commented that it can but i dont know
Many things can cause a misfire. You can look at the P030x code listing in the OBD2 subsection of the Tech Article (DIY) area for ideas in that regard.
A clogged cat could cause this condition, but that would also have other associated issue.
Thanks for the info i will check out the (DIY) Thanks Alot
So the blazer is fixed, I took it to my friends shop & he was checking it for about 3 hours he checked the compression, injectors etc....
Since a tune up had been done about a month ago before the car started acting up we didnt bother to replace the cap & rotor and spark plugs.
The problem resulted to be the thing we least expected, Which was the (dist. cap)
I guess this thing was made with a defect.
Since the car was misfiring so bad i had to replace the spark plugs once again
and my friend only charged me $75 dollars for the dignosis fee and $35 Dollars for parts.
Thanks to all that gave me feedback!
it sucks that i purchased brand new injectors for $330 and the problem resulted to be a $15 part
AreaCode215
Nov 7, 2011 03:07 PM
matt92
May 1, 2011 04:39 PM
Meanagersmom
Jun 13, 2010 11:33 PM
