Just quit running
I have a 96 blazer and had some strange things happen this morning. It started fine this morning and as I was driving there was a little miss. Didn't think much of it, then after a bit I noticed the RPM needle go from 2000 to 4000 RPM. There was no revving of the motor, no miss or anything it just kept on going then the needle went back to normal. This happened a couple of times. After a few more miles (at highway speed) it started missing and jerking really bad. Then it was fine. Then a few more miles down the road it started jerking again. I pushed on the accelerator and nothing. Thinking maybe it was the transmission, I changed gears and no change. then it died. As i was coasting to the shoulder of the road, I noticed that the instrument panel was prett much out. I could barely see the battery light and a few others. After sitting a few minutes on the shoulder, I tried to start it again and it did. I went about another mile and it died again. What I thought was weird is the lights were dim, but after it quits running and trying to start it, the instrument panel if fully lit like normal. After a few more minutes I tried starting it again and it did bu it only went about 50 ft. It jerks and there is no power. Then it wouldn't start.
Here is what I have replaced in the last couple of months:
Battery (show 12+volts)
Dist cap and rotor
Ignition coil
Fuel pump, the relay and filter
Any help would be appreciated
Thanks
Dist cap and rotor
Ignition coil
Thanks
Guest
Posts: n/a
Two things come to my mind. First of course your battery connections and the main ground to the block.
The most important thing to me is the ignition switch, go over to the homepage google box and type in ignition switch and you will see the bizarre host of electrical problems they cause when they start to go.
When mine went it did not cause the exact same problems but close enough.
Think you need a #4 torx socket but really anything that will grab will due. Take the emergency flasher button out first or you will break it. They pull straight up and out.
spittybays I did think about the ignition switch briefly
newguy, I put an airtex pump in it and not sure on cap and rotor. I put the pump in about two months ago. I've heard that airtex could be problematic
Same thing with caps and rotors, second on the leakdown test
I took it to a shop that I use and the problem was the connector that goes to the ignition coil or the icm. Not sure what he said. But which ever one it was the pins were loose and not making a connection. The pins and or plug was replaced and he said that everything seems to fine. The fuel pressure was checked and all was good. He said he started moving wires and that was the culprit. once fixed it wouldn't do it again. Only time will tell
Thanks for the replies
HoustonOKIE
May 31, 2011 09:52 PM
