Just quit running
Old Nov 25, 2013 | 11:00 AM
rlreusch's Avatar
rlreusch is on a distinguished road
Default Just quit running
I have a 96 blazer and had some strange things happen this morning. It started fine this morning and as I was driving there was a little miss. Didn't think much of it, then after a bit I noticed the RPM needle go from 2000 to 4000 RPM. There was no revving of the motor, no miss or anything it just kept on going then the needle went back to normal. This happened a couple of times. After a few more miles (at highway speed) it started missing and jerking really bad. Then it was fine. Then a few more miles down the road it started jerking again. I pushed on the accelerator and nothing. Thinking maybe it was the transmission, I changed gears and no change. then it died. As i was coasting to the shoulder of the road, I noticed that the instrument panel was prett much out. I could barely see the battery light and a few others. After sitting a few minutes on the shoulder, I tried to start it again and it did. I went about another mile and it died again. What I thought was weird is the lights were dim, but after it quits running and trying to start it, the instrument panel if fully lit like normal. After a few more minutes I tried starting it again and it did bu it only went about 50 ft. It jerks and there is no power. Then it wouldn't start.
Here is what I have replaced in the last couple of months:
Battery (show 12+volts)
Dist cap and rotor
Ignition coil
Fuel pump, the relay and filter
Any help would be appreciated
Thanks
Old Nov 25, 2013 | 02:07 PM
spittybays
Guest
Posts: n/a
Two things come to my mind. First of course your battery connections and the main ground to the block.
The most important thing to me is the ignition switch, go over to the homepage google box and type in ignition switch and you will see the bizarre host of electrical problems they cause when they start to go.
When mine went it did not cause the exact same problems but close enough.
Think you need a #4 torx socket but really anything that will grab will due. Take the emergency flasher button out first or you will break it. They pull straight up and out.
Old Nov 25, 2013 | 03:11 PM
newguy's Avatar
Slow down on the ign. switch, What brand of cap rotor, coil, pump did you put in
Old Nov 25, 2013 | 04:56 PM
rlreusch's Avatar
spittybays I did think about the ignition switch briefly
newguy, I put an airtex pump in it and not sure on cap and rotor. I put the pump in about two months ago. I've heard that airtex could be problematic
Old Nov 25, 2013 | 05:23 PM
richphotos's Avatar
oooooooooh that could be your problem, Better do a fuel pressure/leak down test.
These trucks eat aftermarket pumps like candy, Delco/Delphi only.
Old Nov 25, 2013 | 06:18 PM
newguy's Avatar
Same thing with caps and rotors, second on the leakdown test
Old Nov 26, 2013 | 03:39 PM
LannyL81's Avatar
Probably the airtex pump. Lucky you....you get to replace the fuel pump again.
Old Nov 26, 2013 | 07:13 PM
newguy's Avatar
Not really, my truck crapped out and it was the rotor and cap. no warning, just died
Old Nov 27, 2013 | 06:19 PM
rlreusch's Avatar
I took it to a shop that I use and the problem was the connector that goes to the ignition coil or the icm. Not sure what he said. But which ever one it was the pins were loose and not making a connection. The pins and or plug was replaced and he said that everything seems to fine. The fuel pressure was checked and all was good. He said he started moving wires and that was the culprit. once fixed it wouldn't do it again. Only time will tell
Thanks for the replies
Old Nov 27, 2013 | 06:40 PM
spittybays
Guest
Posts: n/a
Great! One bad connection can make the entire electrical system go flunky but if it happens again please consider ignition switch.
dom d
Oct 14, 2014 05:32 PM
HoustonOKIE
May 31, 2011 09:52 PM
rolrod21
Apr 3, 2011 03:01 PM
chevyfan22
Mar 7, 2010 06:27 PM
97blz4x4
Dec 24, 2006 05:11 AM
