JUST WILL NOT IDLE UNDER 2000 RPM ????
Old 06-30-2008, 06:36 AM
CRAZY4WHEELER2's Avatar
CRAZY4WHEELER2 is an unknown quantity at this point
Default JUST WILL NOT IDLE UNDER 2000 RPM ????
GOOD MORNING THIS 95 CHEV S10 4WHD V6 VORTEX WILL NOT IDLE UNDER 2000 TO 2500 RPM,WHAT GIVES,THERE SEEMS TO BE NO WAY TO ADJUST IT "HELP.PLEASE .ALL I GOT ,THANKS
Old 06-30-2008, 06:41 AM
Default RE: JUST WILL NOT IDLE UNDER 2000 RPM ????
Wow... Larger font and caps, you must be in a hurry...
About your problem. Sounds like a large vacuum leak. Start by making sure that your throttle cable isn't bound up in some way (floor mat inside, kink in the cable, carbon buildup in the throttle body, etc). Then make sure that all of your vacuum lines are connected and in good condition. Once you have done that, start the engine and trace the lines and manifold connections with an unlit propane torch, listening for a change in the sound.
Old 06-30-2008, 06:51 AM
THANKS FOR THAT INFO "PLEASE DETAIL THE USE OF PROPANE / I INVISION BLOWING UP SOMETHING,SMILE ,DON'T HAVE A CLUE AS TO HOW TO DO IT,THANKS A LOT
Old 06-30-2008, 07:24 AM
Please, Please use correct capitalization... It makes your posts difficult to read. Caps should not be used!
As far as the use of propane, just open up the torch (one of those little plumbers torches) and trace the lines. There isn't enough propane coming out of the torch to cause a big fire or explosion.
jello219
09-03-2019 05:19 PM
farley463
01-29-2014 04:51 PM
etowntom
09-07-2010 08:16 PM
814_fye
10-22-2009 01:10 PM
jdblazer
12-17-2006 11:24 PM
Quick Reply: JUST WILL NOT IDLE UNDER 2000 RPM ????
