key is hard to turn
Old Jun 1, 2007 | 06:42 AM
Booztd's Avatar
Booztd is an unknown quantity at this point
Default key is hard to turn
i have a 97 Blazer and lately the ignition has been giving me problems. the latest one is the ignition wont go into the lock position but luckily my key is worn down enough so i can take my key out. but now it is becoming hard to turn the key to start the truck ( a lot of resistance when i turn the key) this only happens sometimes but more often than not. is the ignition module going bad and is there a temporary fix for it cause i am buying a new vehicle in about a month or so. thanks
Old Jun 1, 2007 | 09:47 PM
20Blazer00's Avatar
Default RE: key is hard to turn
Sounds like the lock cylinder needs replacing....remove the steering column cover and you should find a small hole to put an allen wrench/screw driver into to push on and remove the cylinder....with the key in the cylinder....then you can install new cylinder in reverse order....
changeme20
Oct 24, 2020 02:12 AM
litterbug
May 6, 2011 08:23 AM
bigjblaze
Oct 19, 2009 07:11 PM
dannao
Sep 6, 2009 11:41 AM
shadwell
Dec 3, 2007 01:09 PM
