key hard to turn into accessory
Old May 4, 2011 | 07:27 AM
litterbug's Avatar
Default key hard to turn into accessory
hello all. its been a while since ive been on here. but now that its warmed up i ran back into a problem that i have had the whole time. my key does not want to turn back into the accessory position. it seems like i have to turn it forward about 30 times before it decides to go into the slot. like it has to be just right in order for it to work. i spent about 5 minutes trying to get this to work at the drive in theater.
so is there a way to just lube it up? like is it safe to just shoot some WD-40 down the key hole and see if it works? i dont want to ruin any electronics or anything so some advice here would be useful.
thanks guys.
Old May 4, 2011 | 03:39 PM
step66's Avatar
Do NOT shoot WD-40 into the ignition switch!!! Use the search feature on the site to give you proper remedies to this common issue!
Old May 5, 2011 | 06:39 AM
litterbug's Avatar
ive done that. i cant find anything on here about that. ive been on here before a few times and i know what not to do.
Old May 5, 2011 | 09:54 AM
96BLAZE's Avatar
96BLAZE is on a distinguished road
i've had this problem for a long time. if there is a way to fix this, please inform
Old May 5, 2011 | 04:21 PM
step66's Avatar
As I have not had this specific issue, I can only relate fixes to earlier GM trucks that had the same problem (70's thru early 90's) sorry! step66
Old May 6, 2011 | 08:06 AM
litterbug's Avatar
well what did you do? maybe the solution to that problem can help here somewhat.
Old May 6, 2011 | 08:23 AM
Omega Ra's Avatar
Omega Ra is on a distinguished road
I had a similar problem in my 01 Saturn SC2, and in the long run I had top replace my ignition cylinder.
stevehendo34
Feb 14, 2012 01:25 PM
dannao
Sep 6, 2009 11:41 AM
Booztd
Jun 1, 2007 09:47 PM
bigt61
May 29, 2007 01:56 PM
TheRealFitz
Nov 25, 2006 07:05 AM
