key wont turn back all the way
Lately I've been having a problem where my key won't turn back all the way so that i can get it out of the ignition. I play with the shifter and the steering wheel and have to mess with it for a few minutes sometimes. I don't know if the steering wheel or shifter have anything to do with it. Any bit of help would be greatly appreciated, thanks.
It's a 2000, automatic column shift.
I'll give the dry lock lubricant a try, thanks.
Last edited by swartlkk; Feb 24, 2010 at 01:55 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has not replied.
Give the dry lube a try and make sure your key is in good shape. If that doesn't work then it's probably the ignition lock cylinder. Other possible culprits are the shift linkage adjustment and/or the linear shift assembly, but that's not likely.
Badco
Apr 3, 2014 12:03 PM
lifted99blazer
Mar 1, 2013 01:45 AM
dist6blazer
Jan 1, 2008 04:46 PM
