key wont turn back all the way
Old Feb 24, 2010 | 04:14 AM
dbennett0307's Avatar
dbennett0307 is on a distinguished road
Default key wont turn back all the way
Lately I've been having a problem where my key won't turn back all the way so that i can get it out of the ignition. I play with the shifter and the steering wheel and have to mess with it for a few minutes sometimes. I don't know if the steering wheel or shifter have anything to do with it. Any bit of help would be greatly appreciated, thanks.
Old Feb 24, 2010 | 06:10 AM
Sounds like the ignition cylinder is getting stuck. Have you tried some dry lock lubricant in the lock cylinder to see if you can get it freed up?
Old Feb 24, 2010 | 01:33 PM
Last C5's Avatar
Last C5 is on a distinguished road
What year Blazer, auto or manual, floor or column shift - inquiring minds want to know.
Old Feb 24, 2010 | 01:44 PM
It's a 2000, automatic column shift.
I'll give the dry lock lubricant a try, thanks.
Last edited by swartlkk; Feb 24, 2010 at 01:55 PM. Reason: *Combining Consecutive Posts* - Please use the EDIT feature to include additional information in your post if another member has not replied.
Old Feb 26, 2010 | 01:34 AM
Last C5's Avatar
Give the dry lube a try and make sure your key is in good shape. If that doesn't work then it's probably the ignition lock cylinder. Other possible culprits are the shift linkage adjustment and/or the linear shift assembly, but that's not likely.
Jcog7293
Jan 31, 2020 09:53 AM
Badco
Apr 3, 2014 12:03 PM
lifted99blazer
Mar 1, 2013 01:45 AM
greasyhands
Dec 18, 2012 06:42 PM
dist6blazer
Jan 1, 2008 04:46 PM
