Keyless remote help
Old Jul 27, 2008 | 08:46 AM
KyleS4562's Avatar
KyleS4562 is an unknown quantity at this point
Default Keyless remote help
I have a 2001 chevy blazer ls. The other day i lost my keyless remote fob at six flags (I think on the superman but that irrelevant). Lucky the dealer gave me two of them. Unlucky the second one never worked. Now that I need the second one I tried to reprogram it(also to cancel out the lost one) but when I tried I had no sucess. I got into the prgramming mode in my blazer fine, but when I held down the lock and unlock buttons on the fob nothing ever happened. So i tried checking all the door, re-entering thr programing mode and holding down the lock and unlock buttons on the fob for 2 minutes and still no lock cycling.
The code on the back of the fob GM/UTA 15732805 and I was wondering if this was the right code for a 2001 chevy blazer? I think it might just be broking but I want to make sure before I buy a new one.
Old Jul 27, 2008 | 08:54 AM
Default RE: Keyless remote help
You have to match the FCCID with that on the remote (T code) with that on the receiver (R code). If they do not match, it won't work. Also, have you checked the battery in the remote?
Old Jul 27, 2008 | 09:03 AM
KyleS4562's Avatar
The batter is fine I checked that before I began the process. accindently left that out. The FCCID number on the remote is KOBUT1BT. Where do I find the R code?
Old Jul 27, 2008 | 01:34 PM
The receiver code should be KOBUT1BR (IIRC) and it will be on the label affixed to the RKE module. The RKE module is located on top of the lower hush panel under the steering column, directly behind the data link connector.
Old Jul 27, 2008 | 09:36 PM
KyleS4562's Avatar
I checked the RKE code and it was KOBUT1BR. I am confused once again because the only two codes for the FCCID on the fobs I can fine are KOBUT1BT and KOBLEAR1XT.
So I am assuming that the T at the end of the FCCID code is for transmitter and the R on the end of the IIRC is for reciver so I would need to buy a KOBUT1BT and my other one with this code is broken?
Does that make sense?
Old Jul 28, 2008 | 05:59 AM
Sounds like the transmitter you have busted somehow. You would need to have a KOBUT1BT fob to match up with your system.
Old Jul 28, 2008 | 08:35 AM
KyleS4562's Avatar
Ok thank you man. You pretty much are blazer forum
Cruiser64
Jan 22, 2012 12:50 PM
ComputerNerdBD
Oct 16, 2011 06:10 PM
lemon blazer
Dec 30, 2007 09:31 AM
terriosouthstar
Dec 17, 2006 10:17 AM
cragpretzel
Nov 28, 2006 11:52 PM
