AC Question
Old Jul 28, 2008 | 05:27 PM
2klt's Avatar
2klt is an unknown quantity at this point
Default AC Question
What is safe time limit to keep l/s press sw. jumped to engage clutch to add r134?
If I fab a fused jumper, what amp fuse?
Old Jul 28, 2008 | 11:08 PM
Default RE: AC Question
If you are just using the jumper to add refrigerant, don't worry about it. You aren't running high current or anything through the jumper wire, it is a low voltage, low current signal wire that tells the PCM that there is adequate pressure in the system for safe system operation.
2001Blue
Lifting Tech
Jan 1, 2011 07:15 PM
98Ltblazer
Apr 11, 2010 11:34 PM
Numba1Sean
May 6, 2009 11:48 PM
redfan13
Mar 11, 2008 09:37 PM
Chadoo951
May 6, 2007 07:01 PM
