Leaf Spring End Tip Pad Anti Squeak
Old Aug 13, 2014 | 09:18 PM
Does the vehicle have 4 wheel drive? There is definitely a vacuum leak in the HVAC vacuum supply. Which could be causing the low lambda voltage. Possibly a faulty vacuum check valve. Is the vehicle right hand drive or left hand drive? In the image below, you can see the power brake booster and master cylinder on a left hand drive vehicle.
Old Aug 13, 2014 | 09:32 PM
rexmburns's Avatar
Super Moderator
Your welcome for my response but the thanks goes to captain! He's far more knowledgable than I with the tech side so your in about the best hands you could hope for at this point as far as I'm concerned!
Old Aug 14, 2014 | 02:56 AM
monette999's Avatar
monette999 is on a distinguished road
Captian yes it is a 4x4 and I am driving on the same side as you in the US.
Only UK still have Pounds as currency & driving on the wrong side.
Shall I start plugging the cuircuts ti identify the leaks cuircut?
BR
Bob
Old Aug 14, 2014 | 03:13 PM
monette999's Avatar
BR
Bob
Today I made some test with my vacuum tester. The Reservoir and vacuum switch are leak free. The line to the AC pannel looks to loose some pressure. The check valve is OK but i habe replaced it. Will See if it works now after i habe replaced some lines.
BR bob
ChevyBlazer4uHaters
Jan 9, 2014 03:39 AM
Skinny1965
Lifting Tech
Dec 1, 2013 10:48 AM
WickedBlazer
Sep 12, 2012 03:14 AM
musclemasterflex
Suspension Tech
Aug 26, 2011 09:10 AM
thrash902
Sep 15, 2010 10:52 PM
