Lights Problem!
Old Jul 25, 2007 | 05:44 PM
Maldo15d's Avatar
Maldo15d is an unknown quantity at this point
Default Lights Problem!
um, i have a 2001' and my lights work when they need to, but when i put on the brights the driver side turns off, and its getting me pulled over all the time, how can i fix that? and how much could it run for$$$?[:-]
Old Jul 25, 2007 | 05:47 PM
lastcoupe's Avatar
lastcoupe is an unknown quantity at this point
Default RE: Lights Problem!
You probably just have a blown high beam bulb. You can pick one up just about anywhere for under $15.00.
Old Jul 25, 2007 | 05:51 PM
Maldo15d's Avatar
no i replaced it and still nothing...
Old Jul 25, 2007 | 07:03 PM
drperry's Avatar
Does your lowbeam on that side come on when you turn your highbeams on?
Check your headlight fuses in the fusebox under the hood...
Old Jul 25, 2007 | 07:17 PM
Maldo15d's Avatar
all fuses are good, also checked that out earlyer and made my brother test them.. i think i might have somthing to do with the ampage and volt distribution senser... na jk.. um they all work when i click the beams on and dont let go, but as soon as i let them go it turns off
Old Jul 25, 2007 | 07:41 PM
lastcoupe's Avatar
That sounds like a bad headlamp dimmer switch, which is only replaceable as a multi-function switch assembly...gonna be a few hundred dollars if that's the case.
Old Jul 25, 2007 | 08:12 PM
Maldo15d's Avatar
so your telling me to go through the dealer?
Old Jul 28, 2007 | 09:13 PM
brock's Avatar
brock is an unknown quantity at this point
I was having the same problem, it was a bad ground, I had to add a ground wire from the light to the sheet metal behind it.
Old Jul 29, 2007 | 02:23 AM
lennyblazer's Avatar
lennyblazer is on a distinguished road
Yeah I would try that first since that is practically free compared to a dimmer switch or multi function switch replacement/repair.
-Lenny
Old Jul 29, 2007 | 05:28 AM
Difference being in the design of the headlamp circuit... A '97 is not the same as a 98+.
Steeltoe623
Nov 12, 2011 03:10 PM
edavison
Dec 20, 2010 09:55 PM
ewingmh
May 13, 2007 07:21 AM
98BlackBlazer
Aug 28, 2006 01:31 AM
rryker
Apr 25, 2006 04:14 PM
