limp mode with code
Old Nov 8, 2010 | 03:49 PM
bigjoewebb's Avatar
bigjoewebb is an unknown quantity at this point
Default limp mode with code
need some help, i have a 1996 4x4 blazer thats in limp mode and is pulling a code p1886....ive replaced the shift solenoids, had all my ground wires checked, but this code is still present...any ideas what the problem could be? Also, it only goes in limp mode after it warms up, but if i turn it off for longer than 2 minutes, i can restart it, then it starts in first, hard shift to 2nd, then third, then back to limp mode......help!!!!
Old Nov 8, 2010 | 08:27 PM
84BlazerS10's Avatar
I'm not sure what a p1886 would be it is not listed in the OBD II troubleshooting codes list.
https://blazerforum.com/forum/tech-articles-diy-29/posted-obdii-trouble-code-diagnosis-26408/
but I know that a bad ecm or bad camshaft position sensor will cause it to go into limp mode.
Old Nov 8, 2010 | 08:34 PM
bigjoewebb's Avatar
from what autozone's scanner reads, smh, its a 3-2 shift solenoid valve assembly circuit electrical fault.....explanation: ECM has detected an open or short to ground in 3-2 SS valve assembly.....probable cause: open or short circuit condition, poor electrical connection......
Old Nov 8, 2010 | 08:59 PM
69chevelle's Avatar
69chevelle is on a distinguished road
did you check continuity in the wire from the ecm to the transmission plug?
don't ask me what wire, I have no idea....
Old Nov 8, 2010 | 11:28 PM
That would probably be the next place to look.
Pobey
Aug 5, 2010 05:21 PM
dready1084
Mar 12, 2010 10:10 AM
mrblonde108
Feb 4, 2010 11:36 PM
BlackFireLS4.3
Jan 29, 2010 10:00 PM
deadgoon20
Oct 30, 2008 02:03 PM
