loss of heat then overheat
changed heater hoses, replaced stat. filled her with water and she is gushing. Where the heater hose connects to the intake there is a adapter that the hose connects to. I can not see if it is from the adapter or the intake. Definitely not the hose. I am feeling some dread because I was hoping it would be the adapter that I could replace. Intake sounds like money.
![Frown](https://blazerforum.com/forum/images/smilies/frown.gif)
Junk yard ,wont be that bad. If thats what it is
Wait a minute, the heater hose connects to your water pump
one does, one doesn't.
I'm hoping it is the quick disconnect/adapter. Waiting for engine to cool and gonna look some more after I take everything back apart.
Water is flowing right under that adapter but I cannot tell if it is coming from it or if I have another issue in that area.
good luck
It's not the connector. Sigh. I can't see a crack but I can see a gap where the intake bolts down. I tried tightening it a little but it is still flowing. Dunno if it is a gasket or a warped intake. It looks a little eroded or warped in the spot where it is coming from. Guess this isn't going to be a simple fix.
Dozer, wont be as hard as you think. You`ll do fine
