loud bang when in 4x4 from front left
Old Oct 12, 2010 | 01:17 AM
spaceapex's Avatar
spaceapex is on a distinguished road
Default loud bang when in 4x4 from front left
put my blazer in 4x4 on a dirt road yesterday and it started banging really loud (you could feel it) from the front left of the truck.. Whats the 1st thing I should check? I just had arm surgery and really don't want to pull more than I have to.
Old Oct 12, 2010 | 09:38 AM
Thor_449's Avatar
Thor_449 is an unknown quantity at this point
Banging could be coming from a lot of things. Is it banging in tune with the engine? or speed of the vehicle? If it's the later then it could be a cv shaft or posibly a wheel bearing.
Old Oct 12, 2010 | 09:45 AM
OILCOUNTRY's Avatar
OILCOUNTRY is an unknown quantity at this point
I would check your Transfer case fluid levels, I had a similar bang and it was due to there being no transfer case fluid in there when I first bought the vehicle. you can almost feel it directly under your feet. Hope this helps.
Old Oct 12, 2010 | 12:25 PM
spaceapex's Avatar
yours was ok after adding fluid? Sounds like catastrophic damage was being done.. as soon as I got it back in 2x2 (took almost a minute) it was fine again.
Old Oct 13, 2010 | 01:06 PM
OILCOUNTRY's Avatar
Well it was running great( with the occasional slip when driving consistantly in 4wd) until I had an unfortunate misdiagnosis involving the transfer case, long story short YES. It did help. When you drain the transfer case fluid drain it into a clear pop bottle. Let it settle and look at how many metal shavings come out. This is a good way to see how much damage has been done. Hope it all works out for you.
Old Oct 19, 2010 | 09:44 PM
spaceapex's Avatar
wouldnt it still bang in 2x2 if it was one of those? I crawled under there and don't see anything wrong. how do you check the cv joints?
Old Oct 21, 2010 | 07:48 AM
taxman91's Avatar
taxman91 is on a distinguished road
I am having the exact same problem with my '98. I'm pretty sure it's the drivers side CV shaft, because you can hear a slight clicking from the left side with the window down. And the banging changes with vehicle speed for me. Any other things to check before I tear into it this weekend would be helpful though.
uhlhazard
Aug 8, 2014 09:00 AM
Bono4783
Feb 4, 2014 10:47 AM
ComputerNerdBD
13
Dec 2, 2011 07:12 PM
cahlersmeyer
Nov 8, 2011 04:12 PM
hoppy2
Suspension Tech
Nov 17, 2006 03:31 PM
