loud roraing noise when cold, touchy pedals
Old Apr 20, 2010 | 08:46 PM
Nemo1991's Avatar
Nemo1991 is on a distinguished road
Default loud roraing noise when cold, touchy pedals
so ive had my blazer for about 8 or 9 months and ever since i got it ive had this problem, when i first start it up, especially on a cold day, for about 5 minutes it makes a loud roaring noise. and also, some days the gas and brake pedals are touchy, like ill barely press the gas and it will respond quickly and will be fast, and the brake will stop when i barely tap on it. but on other days, it feels almost as if i have to press down on the gas and brake pedals with all my might for anything to happen? anyone have any ideas on whats causing this?
Old Apr 20, 2010 | 08:55 PM
1998MSO's Avatar
1998MSO is on a distinguished road
The loud roaring noise could be your fan clutch. While it's not unusual for it to "roar" for a bit (usually less than a minute) 5 minutes in cold weather indicates the clutch may be sticking.
Old Apr 20, 2010 | 09:53 PM
Nemo1991's Avatar
thanks ill check it out
Old Apr 21, 2010 | 11:31 PM
portcqb's Avatar
portcqb is an unknown quantity at this point
If you rev to say 2k and let it go back to idle will the roaring stop? As for the pedals that sounds odd the throttle is mechanical so it shouldnt respond differently unless the engine is performing differently
Old Apr 22, 2010 | 01:08 PM
Nemo1991's Avatar
no it doesnt stop. it happens when i take off, but once i get into 2nd gear it goes away, but if i slow down or stop and have to get going again within a couple minutes it still does that till i hit 2nd gear
Old Apr 23, 2010 | 09:05 AM
dman001948's Avatar
dman001948 is an unknown quantity at this point
I just recently install a new "Heavy" duty Fan Clutch and boy does it make the noise for a short while, put it goes away quickly. Also it kicks in around 195-200 degrees when the old one (ready to go out) would kick in at 210 or above, then it just stop kicking in. One pain in the butt to change out, but worth it. If you do have to change one opt for the heavy duty one, its better and will last longer, a little more roar..but one gets use to it.
phxjosh
Jun 20, 2013 04:29 AM
BuddyS
Mar 27, 2013 10:11 PM
247monster
Aug 31, 2012 05:54 AM
dimmuborgir6nik6
Dec 30, 2007 09:09 PM
merlinator
Jul 20, 2006 10:53 PM
