Low oil pressure
Old Mar 8, 2020 | 06:59 PM
Joshua Brock's Avatar
Joshua Brock is on a distinguished road
Default Low oil pressure
I changed my oil and all of a sudden I have lower than normal oil pressure it's around 20 till I'm idling then its 0. I had a leak in my spider injector and when I replaced it I changed the oil because it had leaked gas into the oil. I got a new pressure sending unit and I'll see if that help but I'd like to now if there is something else.
Old Mar 8, 2020 | 09:41 PM
Mods's Avatar
to be clear - how much gas was in the oil, was it enough to dilute it? and did you wait a bit before starting the motor after refilling? how much oil did you put in and is there any knocking, wavering of the gauge, etc.
Old Mar 10, 2020 | 10:13 AM
93S10TahoeLT's Avatar
Just curious, what would "wavering of the gauge" mean?
Old Mar 10, 2020 | 04:28 PM
Mods's Avatar
quite literally is the gauge waving about or is it steady on low pressure at idle, a bit of movement is movement is expected but if the gauge is moving erratically then it would point to the pressure sender if there is no knock.
Gnd
Jan 10, 2020 04:59 PM
hellblazer
Oct 22, 2012 05:19 PM
punnerab
Jun 17, 2009 11:34 PM
88s10Blazer
Nov 6, 2007 07:57 AM
ivannj
Feb 13, 2006 02:58 PM
