oil pump low pressure
Old Oct 15, 2012 | 07:41 AM
hellblazer's Avatar
hellblazer is an unknown quantity at this point
Default oil pump low pressure
i wanted to know f anybody knows why the am i getting low pressure reading ob my oil gauge.i just changed the oil sat.and this morning i noticed it being at 35psi.what is normal reading supposed to b.
Old Oct 15, 2012 | 07:52 AM
Bdub's Avatar
Bdub is on a distinguished road
I think mine is 40 at idle fully warmed up
Old Oct 15, 2012 | 08:01 AM
05BlackJimmy's Avatar
05BlackJimmy is on a distinguished road
I know the gauge is supposed to be almost at the middle while idling and when accelerating it goes up past the middle. Did you check the oil level?
Old Oct 15, 2012 | 08:37 AM
newguy's Avatar
oil does get thinner when warm, which would show less pressure. What weight did you put in?
Old Oct 15, 2012 | 09:10 AM
rriddle3's Avatar
Rule of thumb: 10 psi needed for each 1k RPM. GM specs 8psi minimum for our engines.
Old Oct 18, 2012 | 05:39 PM
hellblazer's Avatar
i use 5w30 high mileage castrol gtx.i guess its normal.thanks eveyone.
Old Oct 22, 2012 | 05:19 PM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
Default 40 psi @ idle after fully warmed is good.
My 4.3 in my truck starts up at 60psi.After it warms up it stays around 30psi at idle.I had a van with the same engine oil pressure was about the same till rod bearing started going bad.
musclecar70sfan
Sep 30, 2010 06:58 AM
rohde782
Oct 8, 2009 08:36 PM
Bigblue
Oct 1, 2009 01:43 PM
noom14921992
Nov 9, 2008 05:16 PM
s10_1997
Mar 28, 2008 02:30 PM
