Low pitch noise coming from heater fan
hey guys, I have a 98 blazer, had a/c work done on it over the summer. A/c works fine, heat works fine, but recently the fan started to make a low pitch, low frequency noise. like "thththththththt" There is a lot of airflow, so I don't think there is anything wrong with the fan itself. I removed the glovebox, and can see the valves open and close when I move the selector ****.
The sound is the loudest (and its really loud) when I have it on any setting other than defrost, although I can still hear it. And of course it's the loudest when the fan is on high, and gets almost unnoticeable at about low-mid setting.
I dont think i can see anything without taking the entire fan assembly out. :/
im not exactly sure, If i had to guess i would say that plastic piece that goes across the bottom of your windshield. that's probably the only place they could get sucked into i think, and when you have your air on high you can hear it sucking in air. There's a plastic piece with the grates then theres the piece above that with a small gap between it and the windshield that is perfect for a leaf to fit into, and i think that's where they get sucked into. the other day mine sucked one in and it was making a horrible noise, and i just kept playing with the fan speed and it finally stopped. anymore i clear the leaves off before i start my truck.
Edit: dont know what i was thinking. those two plastic pieces i was mentioning are one piece. but what step66 said is what i would do.
The cowl vent lets in all sorts of leaves this time of year:normal! Its been happening since they put heat in cars. Run it for a couple weeks until fall ends in the Seattle area and if it doesn't go away by mid Dec just throw a new blower motor in! 'cause if it IS the motor,it will get worse when colder temps come and you will want full ventilation for the winter!
kelly2
May 8, 2015 09:10 PM
GloryImSaved
Jul 14, 2009 06:26 PM
chevyblazer2008
Jan 8, 2008 05:44 PM
