Fuel pump is making high pitch noise
Old May 8, 2015 | 01:01 AM
kelly2's Avatar
kelly2 is on a distinguished road
Default Fuel pump is making high pitch noise
2000 Blazer LS, 156xxx miles.
It is hard to start at first time no matter morning or night, after few attempts then drains the battery out, by using the jump start cable it can fire up. Engine is not willing to rev up but stalls a little at 3k-4k range if pedal to the metal when in park, not even mention in drive. Once it starts and as long as the engine is warm enough it can start right the way. when engine is runing I can hear the winning high pitch noise from somewhere near the fule pump, check this video.
I have changed all spark plugs, fuel filter,seaformed in past 1k miles, no any luck. Have mechanic checked fuel pressure they said it was good but alternator was overcharging.
Do I need to double check the fuel pressure? or the fuel pump is going to out because I never heard the winning noise before its hard starting issue. Or anything else I can do for it on minimum cost(DIY)
Every input will be thankful.
Old May 8, 2015 | 03:29 PM
Here is your first step:
https://blazerforum.com/forum/2nd-ge...eakdown-88305/ Post all 4 readings.
Old May 8, 2015 | 03:52 PM
newguy's Avatar
Other than the fuel pressure test, mine did this when I installed a new one. Had a kink in the line exiting the pump
Old May 8, 2015 | 04:16 PM
kelly2's Avatar
Well that is odd but I will still start from there first.
Old May 8, 2015 | 09:10 PM
abig84's Avatar
my 93 which ive owned for 7 years has been that loud for as long as ive had it. i actually kinda like it cause i know once that sound is gone and the truck dont start i know what it is
swanman35
Jan 11, 2013 04:18 PM
Greg828
Dec 2, 2012 10:58 AM
kuojo
Mar 28, 2012 07:22 PM
GloryImSaved
Jul 14, 2009 06:26 PM
chevyblazer2008
Jan 8, 2008 05:44 PM
