Low voltage at fuel pump
I have a 95 S10, Vortec v6,4.3,4door, 4 wheel drive. It has low fuel pressure. With a brand new Bosch pump in. So I ck voltage at pump. Its only 8.6 volts. Everywhere else I ck I get 12. What am I missing????
Just a friendly FYI: aftermarket fuel pumps are NOT recommended on 4.3L Vortec engines, AC Delco or Delphi only, unless you like changing the pump
When the ignition is turned to the RUN position, (engine off) the fuel pump is only energized for 2 seconds, so you must check voltage during that 2 second time frame. Have you checked resistance from the fuel pump module electrical connector to ground? Must be less than 5 ohms. Which style connector is on the pump module?
My bad, 1995, sorry. 30 ohms is too much resistance in the ground circuit, (probably what toasted the old pump). Solder on a 14 gauge piece of wire at the module connector and run it to a good, clean, body ground.
Capt. Hook. Thank you very much. Did that tonite. 1ohm. Hopfully this all works out. Darn tired of droppin that tank.
RJWolfe
Feb 17, 2019 07:32 PM
NV4x4BLazer00
Mar 10, 2012 08:57 PM
2001Blue
Dec 31, 2010 12:16 PM
cjp5
Sep 15, 2010 07:51 AM
