Lower intake gasket replacement
Old 02-28-2021, 05:52 AM
rsaunders80's Avatar
rsaunders80 is on a distinguished road
Wow. This is incredibly helpful, thank you so much. A little light reading to do before I go much further in my disassembly.
So it sounds like I don't need to remove the PS pulley, which is very okay with me. I expected that the pulley may hold the aluminum bracket in place if it's not removed. I'll remove all of the nuts/bolts and try it first before assuming to remove that guy. Pulley removal is a brute-force PITA and not something anyone wakes up and looks forward to doing.
  #22
Old 02-28-2021, 06:47 AM
How do you use 2 wrenches on the EGR tube? I'll soak mine in penetrating oil and I have a flare nut wrench, but am unsure where the second wrench would go.
  #23
Old 02-28-2021, 05:54 PM
christine_208 will become famous soon enoughchristine_208 will become famous soon enough
Regarding that, I was going by my memory so I could be wrong. I guess the best I can say is be careful.
  #24
Old 02-28-2021, 06:42 PM
Thanks for the input. I went lightly on it after using some penetrating oil and it came out easily.
  #25
Old 03-01-2021, 05:56 AM
What type of RTV should I have on-hand? I know the gasket kit comes with some, but if that runs out I want to have some extra available. I can get black, high-temp red, grey, etc. Red seems like the right application, but there are too many options.
  #26
Old 03-01-2021, 02:22 PM
I like this stuff myself.
  #27
Old 03-02-2021, 09:32 AM
Tajohns34's Avatar
Which kit did you wind up going with?
  #28
Old 03-05-2021, 08:29 AM
puttster's Avatar
puttster will become famous soon enough
Was RTV ever part of the original assembly? I have a hard time visualizing a 1999 assembly line that depended on workers squeezing 3/16" lines of sealant on gaskets.
  #29
Old 03-05-2021, 08:44 AM
I went with the Fel Pro MS 98002 T gasket kit. Taking off the intake manifold I can only assume mine is still stock/original, and it had RTV across the zone between the intake gaskets (what was left of it).
  #30
Old 03-05-2021, 08:58 AM
LesMyer's Avatar
LesMyer will become famous soon enough
You should have been there in the late 70's when GM eliminated a lot of gaskets and went with just orange RTV by itself for oil pan and valve cover gaskets. Bad idea!! It was called G.M.S. (General Motors Sealer). We had a tech we called the GMS kid. He kept a caulking gun with a huge tube of GMS - he would spray leaks down with carb cleaner, smear GMS on the outside, and charge GM for a warranty repair like the part was removed. Same guy knocked over a tray of un-marked rod caps and mixed them up. Spend days switching them around until engine would turn freely again. Didn't last through the test drive.
Quick Reply: Lower intake gasket replacement
