Machined heads... How do I set valves?
Old Feb 18, 2014 | 03:18 AM
jesse309's Avatar
jesse309 is on a distinguished road
Default Machined heads... How do I set valves?
My first time workin on 2nd gen. I understand that u torque rocker nuts and ur done but heads were warped so machined them now if I do it like that I have no compression. Do I need shim rockers up now? About light it on fire watch it burn! Lol
Old Feb 18, 2014 | 11:12 AM
TZFBird's Avatar
TZFBird is on a distinguished road
Technically you would need shorter pushrods by the same amount that the heads were milled. The pushrods are now longer and it is holding the valves open once the rockers are torqued down. I do not know if they make shims for the rocker pedestals or if you will need to go with shorter pushrods.
I would start by finding how much they milled off to get the heads straight and go from there.
Surely it can't be as easy as punching some holes in shim stock and adding it between the head and the rockers.
Old Feb 19, 2014 | 09:36 AM
jesse309's Avatar
Yea that's about where I'm at. I see the studs are screw in I'm thinkin it be better to shim the stud up. Rather then the rocker on the stud. Thank you for the reply
NOs
Sep 1, 2016 12:09 PM
lakeblazer91
Feb 16, 2009 02:55 PM
strong blazer
Apr 6, 2008 02:22 PM
dude5l
Jul 19, 2006 01:00 AM
R.R
Mar 8, 2006 10:57 PM
