General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Valves hanging open
Old Jul 18, 2006 | 06:39 PM
dude5l's Avatar
dude5l is an unknown quantity at this point
Default Valves hanging open
Hey everyone. I have a problem with a 99 Blazer. I just replaced the head gaskets on it and when I bolted everything back up and tried to start it it had NO compression. I removed the valve covers, and sure enough none of the valves are closing. the rockers are a positive stop style and I torqued them to 20lb/ft. I have no idea why this has changed. Has anyone ever heard of this before? The only thing I can think of is the lifters are not bleeding down. Any other Ideas?
Old Jul 18, 2006 | 08:29 PM
Default RE: Valves hanging open
So you removed the intake manifold, exhaust manifold, then the heads? I know there is a lot more to it... Did the lifters or valve springs ever get removed?
I guess it is possible that the lifters aren't bleeding down properly... How long did the vehicle sit before repairing the blown head gasket?
Old Jul 19, 2006 | 01:00 AM
Chevy Lover's Avatar
I'm guessing that you changed the oil after your repair. If the engine sat for a long time I would leave the spark plugs out and crank the engine for a minute to circulate the oil, stop cranking for a couple of minutes to allow the starter to cool down and repeat this a few times to see if things start working properly after the oil has been pumping thru the engine. I'ts possibly a oiling problem in the lifters, but try this a few times and see if it works.
Let us know.
chris015
Feb 14, 2012 10:20 AM
coorsoman
Mar 31, 2011 04:18 PM
goldrushusmc
Aug 8, 2009 11:48 PM
zippy199
Aug 2, 2009 01:58 PM
Canadian88
Jul 20, 2006 08:41 PM
