MAF or Cat Converter
Old Apr 13, 2012 | 11:57 AM
Annie's Avatar
Annie is on a distinguished road
Ok so there a few more. Codes than I was told....
P0102
P0131
P0134
P0452
P0300
And was told MAP reading 13.3
Old Jun 17, 2012 | 02:50 AM
WalkGood's Avatar
WalkGood is on a distinguished road
Any more progress on this problem?
Old Jun 19, 2012 | 06:45 PM
goodcheeseburger's Avatar
goodcheeseburger is on a distinguished road
You poor thing. As mentioned before that shop is either totally dumb, or taking you for a very expensive ride. I just recently had two instances that have alot of the same issues you are having. First, random missfire. Mine was caused by a defective rotor, the spark would fire straight through the rotor.. might take the dist cap off and inspect the cap and rotor for any burns. Even a tiny burn mark can mean the spark isn't going where it's supposed to. Second, cleaning the MAF and EGR will, at a min, help with fuel economy so I would def do that. Also, try removing the two O2 sensors that are before the Cat Conv. It will be loud, but if it drives alot better it is a good sign that your Cat is clogged up. (this trick got me home from work and to the parts store to buy the new Cat when mine failed)
Old Sep 23, 2012 | 04:05 PM
Annie's Avatar
Angry
Hi sorry so long since update.
Things have gone from bad to worse... And i can only blame myself!!
Performance issues only got worse. Oil pressure gauge started going all over the place. So I suspected oil pressure switch was going bad. I also read this could cause some of my performance issues I've been experiencing. So I bought a new sensor... Thought I did my research!!! (this is why this is my fault). Once I got the appropriate tools getting the switch changed was that terribly difficult.
My problem comes when i put the things back together- it wont start. It tries but never turns over. I learned my mistake was when I removed the distributor cover and then shaft I didnt mark anything. So I'm 99.999% positive that i messed up the alignment when placing it back or taking it out.
I am assuming there is no easy way to fix this ... Is there?
Its a 2000 Blazer 4.3L.
Sooo Stressed Out!!
Annie
Old Sep 23, 2012 | 07:20 PM
spittybays
Guest
Posts: n/a
Can you put a list up of what's been done, it's hard to read in long form. Thanks.
Old Sep 23, 2012 | 07:37 PM
Annie's Avatar
Shop changed fuel pump, fuel regulator, fuel filter. I Cleaned MAF sensor, changed air filter. Today we changed oil pressure sensor and now it wont start...
Old Sep 28, 2012 | 06:22 PM
Annie's Avatar
FIXED!!! Finally got the timing reset! The engine hasnt sounded this good in years! So changing the oil pressure sensor, the spark plug wires again and get the timing right seems to have fixed my issues!
Thanks to all who offered advice and guidance!
Annie
hillbillys10
Apr 14, 2013 01:04 PM
Squad-6
Headers, Intake, & Exhaust
May 17, 2011 10:29 PM
Bullfrog2099
Dec 16, 2010 07:25 PM
PaulO2288
17
Jan 20, 2010 01:39 PM
djbass_mekanik
Apr 22, 2006 06:15 AM
