Maiden in distress,having to turn key hard-95 blazer
Old Aug 9, 2009 | 12:47 PM
dannao's Avatar
dannao is on a distinguished road
Default Maiden in distress,having to turn key hard-95 blazer
Two weeks ago my blazer got harder to start. In order to start the car I have to turn the key past it's normal starting position. I turn it to the point I have always turned it to and get nothing. Then I push it a bit harder and it starts. The past few days I have had an even shorter distance to push the key. I am afraid that space will disappear soon and I wont be able to start it at all. I have done alot of work on my Blazer (including changing my fuel pump and fuel injectors). I am a quite capable mechanic with great common sense. I need your help on this one, I just cant figure it out. I need to drive 800 miles on Friday for my childs Doctor appointment and I would like to fix this before I go. Please help.
Old Aug 9, 2009 | 12:50 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
sounds like the ignition switch is bad
Old Sep 6, 2009 | 11:41 AM
dannao's Avatar
Thank you Reelbroke. It was the ignition switch.
I want to say that Wolfpack's ignition switch replacement instructions were very helpful in helping me get this work done. I want to note that others had said to use a 4mm socket where the T4 torx is needed. I tried the 4mm and other tools I could think of to get that screw out at the top of the column and none of them worked . I looked all over for a T4 TORX but no success locally. I finally tried a T5 TORX and that was loose but worked .
changeme20
Oct 24, 2020 02:12 AM
litterbug
May 6, 2011 08:23 AM
Cidium
May 2, 2011 12:28 AM
Booztd
Jun 1, 2007 09:47 PM
2 Big Blazers
Mar 29, 2007 08:13 PM
