Maintenance and coolant leak
Old Mar 17, 2018 | 03:29 PM
blazedblazeroffroad's Avatar
blazedblazeroffroad is on a distinguished road
Question Maintenance and coolant leak
I have a 2001 2dr Blazer LS, I got it around 7 months ago and I want to keep it running as long as I can. I just had my heater core go and had to pay 800 dollars to get it replaced at a local shop. This got me thinking, what other things should I look at? Im looking to make a list of things that I should start going through and checking/replacing and an idea of where to start, so any input would be great! My other issue is that I think I might have a coolant leak. It always seems low and Ive had to fill it 5 or 6 times since I got it. I filled it when I changed the oil yesterday and Im going to watch it to see if im losing it but where would it be leaking?
Old Mar 17, 2018 | 04:14 PM
On the top of any list should be a replacement of the lower-intake manifold (LIM) gaskets. These are known to fail catastrophically dumping coolant into the oil pan and ruining the bearings.
After that these come to mind:
  • remote oil cooler lines*
  • front end components, especially the idler arm
  • front wheel hubs/beaings
  • all fluids should be replaced (even the power steering)*
  • the underhood vacuum hoses (they will rot and mess up your 4wd and HVAC)
  • worn or stuck brake caliper pins
For the items with the asterisk:
remote cooler lines: these can be more an an annoyance but on my '92 I did have the o-ring on the cooler lines to engine block adapter fail causing a big leak.
automatic transmission fluid: some people will be hesitant to change that fluid as they will claim it will dissolve the gunk that is supplying the friction to the 3/4 clutch plates. I would contend that replacing the fluid is only illuminating a problem that is already there.
Old Mar 17, 2018 | 05:41 PM
Thank you for the answer! I forgot to mention I already had the hoses done as the 4wd didnt work when I got it.
Old Mar 18, 2018 | 01:04 AM
Are you referring to the vacuum hoses? It is amazing how such small things can mess up systems so easily!
I guess I could have added to the list replacing the water pump. I'm considering doing that as preventative maintenance. I'll be using an AC-Delco part to do it. My plan is the keep mine for another 3 to 5 years so I'm comfortable doing such maintenance.
Clancy Pell
Nov 8, 2013 01:36 PM
95BlackGA
Mar 15, 2013 09:46 PM
ComputerNerdBD
Feb 9, 2010 05:05 PM
TAZ454
Jan 28, 2008 10:11 AM
AtreyuManiac
Nov 27, 2007 03:31 AM
