Major whine noise at low speed
Old Nov 8, 2012 | 09:09 AM
TTATE's Avatar
TTATE is on a distinguished road
Default Major whine noise at low speed
Hi....my 99 4w drive blazer is making a very loud whining noise at speeds under 40 MPH. The noise goes away over 40. Sounds as if it coming from the front of the truck but hard to be sure. I coasted the truck with it turned off and the noise went away, so I don't think it's wheel bearing related. Transmission shifts fine and engine runs well. Sounds like an electric motor that runs at high volumn then drops slowly in rpms. Good with mechanical issues but don't have much experience with four wheel drives.
Thanks
Old Nov 8, 2012 | 09:28 AM
chris015's Avatar
To rule out a bad belt pulley,pull off the belt and crank her up. Does she make the sound while at idle?
Old Nov 8, 2012 | 09:41 AM
TTATE's Avatar
Thanks...will give it a shot tonight. Sound isn't there when idling.
Old Nov 8, 2012 | 09:42 AM
chris015's Avatar
see if its there idling,but in gear. maybe it only does it under load.
Old Nov 8, 2012 | 10:03 AM
TTATE's Avatar
Doesn't occur when idling even when it's in gear. The noise starts out at a low rpm then revs up high and loud...then drops down to nothing when totally stopped. Like drilling through something with a hand drill.
Old Nov 8, 2012 | 11:13 AM
TTATE's Avatar
Could it be the encoder motor?
Old Nov 8, 2012 | 12:07 PM
TTATE's Avatar
Pulled the fuse to the encoder motor at lunch, noise gone. Must be jammed or transfer case problems.
Old Nov 9, 2012 | 04:33 PM
98blazin's Avatar
98blazin is on a distinguished road
clutch fan.
Old Nov 9, 2012 | 08:37 PM
Stick the fuse back in for the encoder motor. Drive it til you hear the noise, then select 4WD HI and see if the noise changes. Don't leave it in 4WD, only long enough to see if the noise changes, (4WD should not be used on dry pavement).
Pipewrench Dale
Nov 10, 2014 06:16 PM
mr.vls
Aug 24, 2013 06:03 PM
LioNiNoiL
Aug 4, 2011 02:47 AM
ImScrewed92
May 1, 2010 05:39 PM
