Manifold Vacuum Connection, should it be ON???
Old Mar 3, 2013 | 01:47 PM
chcknugget's Avatar
chcknugget is on a distinguished road
Default Manifold Vacuum Connection, should it be ON???
The Fitting the PCV hose and main vacuum connection to seems to be rotate about 90 degrees. One side says ON and one side says OFF. Which way should it go? As far as vehicle performance goes it doesn't seem to make a difference which side it's on! It's a 1996 GMC Jimmy 4x4.
Old Mar 3, 2013 | 03:22 PM
abig84's Avatar
im kinda confused but the pcv hose should be hooked up to a steady flow of vacuum at all times if you disconnect your pcv hose it wont make the vehicle run any different, on my older vehicles i never ran them.
Old Mar 4, 2013 | 06:45 AM
chcknugget's Avatar
Nevermind, I'm not completely sure but I think the on/off is direction for removing the fitting.
btb1003
Apr 9, 2014 11:08 PM
4thgenceli
Feb 27, 2011 02:07 PM
latinoNJ
Jul 6, 2010 12:15 AM
Blueline
Feb 16, 2009 01:36 PM
mohawks76
Performance & Brainstorming
May 24, 2008 09:42 PM
