manual 4wd indicator
Old Jun 9, 2008 | 03:05 AM
klausjohn1142's Avatar
klausjohn1142 is an unknown quantity at this point
Default manual 4wd indicator
I have a 96 blazer LT with the manual shift 4wd on the floor and automatic transmission. 2wd and 4wd hi and 4wd lo all shift and front hubs lock in and release with out a problem. The little picture showing the front 2 wheels indicator stays lit all the time and will not go out. Has been this way since I bought her a few months ago. Only One time has the indicator gone out, but after using the 4wd hi in a snow storm this last winter it has remained lit. Can anybody give me any ideas.
Old Jun 10, 2008 | 11:18 AM
larryou812's Avatar
larryou812 is an unknown quantity at this point
Default RE: manual 4wd indicator
indicator switch might be bad.switch is located on front diff on the carrier where the cable goes into diff.you are going to have to remove both skid plates up front to access that area.hope this helps
Old Aug 5, 2008 | 01:28 PM
Just thought I'd bump this post back up as the Original Poster can't seem to find it.
Old Aug 19, 2008 | 09:39 AM
I will check that, I assume you are saying that the swich maybe falty and stuck in the on pos. I'll let you know what I find
Northriver
Feb 7, 2014 10:43 PM
sparky672
Jan 29, 2010 01:36 AM
gjgallager
Jan 8, 2010 11:45 AM
BIGGER_HAMMER
Nov 21, 2008 02:00 PM
klausjohn1142
Aug 5, 2008 01:26 PM
