Master cyclinder problem?
Old May 9, 2013 | 01:14 PM
Connie101's Avatar
Connie101 is on a distinguished road
Default Master cyclinder problem?
Today I went to bleed the brakes and noticed that without resevoir cap on the MC it blows fluid out like crazy.. Thinkin thats a bad thing I got a new MC and found it does the same.. I call some guy at advance auto and he says that's normal but I don't see how and I can't seem the get them to bleed right. It blows out the top like it's pushing air up the holes the fluid should be goin down.. Thanks a lot for your help.
Old May 9, 2013 | 02:38 PM
Diaita's Avatar
It is normal. make sure the reservoir cap is on, or you'll have brake fluid everywhere.
Old May 9, 2013 | 03:04 PM
Connie101's Avatar
How does it not loose pressure?
Old May 9, 2013 | 05:09 PM
Diaita's Avatar
As long as the brake fluid is covering the bottom of the master cylinder reservoir, there is no way to get air into the system. The spray up comes from the equalization port at the bottom of the master cylinder reservoir.
bamiejurke
Nov 10, 2011 03:08 PM
justdeb49
Feb 14, 2011 03:32 PM
FlatTopFoley
Nov 26, 2008 01:30 PM
p_j_robertson
Aug 12, 2006 05:21 PM
wythel
27
Jan 30, 2006 02:04 AM
