General Tech Help Good at troubleshooting? Have a non specific issue? Discuss general tech topics here.
Location of Clutch Master Cylinder
Old Jul 7, 2006 | 07:06 PM
p_j_robertson's Avatar
p_j_robertson is an unknown quantity at this point
Default Location of Clutch Master Cylinder
Question
Where exactly in the clutch master and slave cylinders located. I thought that the Master was connected to the pedel assembly and the slave was connected to the transmission itself. The mecanic told me that they were located inside the transmission housing. Is this true and if it is would it be better to also change the complete clutch assembly since the transmission would have to be dropped to get to the master cylinder. Want to see if this mechanic is blowing smoke up my ***
Old Jul 7, 2006 | 08:32 PM
Default RE: Location of Clutch Master Cylinder
The clutch master cylinder is located between the brake master cylinder and the fender. It extends through the firewall and connects to the clutch pedal. A hydraulic line then goes from the master cylinder down to the transmission bell-housing where it connects through a quick connector that leads to the slave cylinder.
The bleed screw is located just above the quick connector for the clutch hydraulic line on the transmission bell-housing. Just make sure that when you bleed the system, that you keep the fluid level in the reservior. It doesn't hold a lot of fluid.
Old Aug 12, 2006 | 04:17 PM
4bangermustang's Avatar
4bangermustang is an unknown quantity at this point
how do you get the line off the slave in the trans??
I see oyu saying quick connector....do you need some kind of special tool??
96 blazer...
Old Aug 12, 2006 | 05:21 PM
blazin97's Avatar
blazin97 is on a distinguished road
ORIGINAL: 4bangermustang
96 blazer...
yes you need a special tool. it came with my clutch kit when I bout it.
road1420
Aug 9, 2015 10:48 PM
702Blazer
Dec 9, 2011 08:57 PM
FlatTopFoley
Nov 26, 2008 01:30 PM
soundguy
Sep 11, 2007 03:05 PM
Jimmiero
Aug 31, 2006 11:15 AM
