metal ticking noise when accelerating
Old Dec 24, 2009 | 11:40 PM
  #21
pmezo's Avatar
pmezo is an unknown quantity at this point
You know... i was thinking the same thing. Maybe he put in the wrong ratio. Thats the only thing i could think of.
Now if he did install the wrong ratio... that couldnt do damage if i run in 2wd only, right? It will only do damage if i run in 4wd?... which im obviously not going to even attempt.
Old Dec 24, 2009 | 11:46 PM
  #22
old skool luvr's Avatar
correct, & correct.
the only thing it'll do, is throw out your speedo.
don't really know how you could explain this mistake away though, other than , "they sent me the wrong ratio".
but then again, i've always checked the math on the ring & pinion before installing it.
Old Dec 24, 2009 | 11:58 PM
  #23
pmezo's Avatar
I'll update on monday when i go back to see this guy. I've got a feeling that ill be reporting back that its the wrong ratio that was installed. Thanks for the help.
Old Dec 25, 2009 | 02:44 PM
  #24
This definitely sounds like another absent minded mechanic messing up by not checking the ratio before swapping in parts.
Old Jun 3, 2020 | 03:45 PM
  #25
Vance Andrews's Avatar
Vance Andrews is on a distinguished road
96 blazer 4wd...
Not sure if the weather has anything to do with it or not, but all of a sudden when i'm accelerating, i'm hearing a weird noise from under the car towards the rear. It sounds like a metal ticking sound coming from the wheels, but it's hard to tell while i'm driving. It only makes the sound when i'm accelerating.
I know it's hard to explain a sound by typing, but it sounds like metal hitting metal. Not a grinding noise like brakes hitting the rotors. The only way i can thinking of how it sounds is if you've ever watched wheel of fortune. It sounds like the ticking from the wheel as it goes around.
The only thing i can think of is bad wheel bearings, but i'm really not sure since i don't have a lift. Any ideas?
My Sonoma is making same sound
Old Jun 3, 2020 | 05:05 PM
  #26
93S10TahoeLT's Avatar
Mine was as well, but, again.. seems to have stopped.
Though, I suspect mine was not suspension/diff related, as changing engine oil and massive de-carbon efforts over the last two days (again. I learned what NOT to do) and it seems to have stopped. Engine shuts off and runs a lot smoother, too, leading me to think something was either really dirty or clogged or stopped up.
Does it sound like a card in a bike wheel?
Does it happen only when turning (usually hard) or just when getting on the throttle, like to keep a hurried pace up hills and you bury the pedal to the floor?
Old Jun 3, 2020 | 05:45 PM
  #27
Old Jun 7, 2020 | 04:46 AM
  #28
Thread from 2009 closed. Last questions have been opened in a new thread already. Please use the new thread.
HFordFett
Jun 1, 2017 02:44 PM
zombieblazer96
May 17, 2015 05:47 PM
nehlert22
Jul 31, 2013 06:31 PM
ridin'blaze03
Jan 12, 2012 07:50 PM
awesomeamerican1
Aug 25, 2010 07:43 PM
