metric or SAE
Are these trucks metric or SAE? 2001+ in particular ... thanks in advance.
They're mixed (both)
What are the most commonly used standard sizes? I have a pretty complete metric set ...
I need to check the vac lines for 4WD issues today, any idea what the bolts on the battery tray are offhand?
Yep, mostly metric.
I just use metric on most things since they increase in size by only 1 millimeter for each wrench.
They work fine for most US standard applications unless you are really putting some tork on a rusty bolt in US standard...then the standard wrenches work better.
![Wink](https://blazerforum.com/forum/images/smilies/wink.gif)
I feel like everything I do on the blazer, I'm always having to use the 15mm socket...which always seem to escape after the first bolt comes out[:@]
Yeah, this is how they line up...
US Metric
1/2" 13mm
9/16" 14mm
5/8" 16mm
11/16" 17mm
US Metric
1/2" 13mm
9/16" 14mm
5/8" 16mm
11/16" 17mm
thanks all
![](http://img139.imageshack.us/img139/7397/socketsbk7.jpg)
Using a 13mm socket on a 1/2' bolt head is a good way to round it off [&o]
