milage help?
Old 10-12-2008, 11:42 PM
sasquatchfound's Avatar
sasquatchfound is an unknown quantity at this point
Default milage help?
I hope i'm posting this in the right place. I need to know what mpg my 1995 S-10 blazer 2-door gets and how many gallons are in the fuel tank?
Thanks, shane
Old 10-13-2008, 12:04 AM
Default RE: milage help?
All you need is a pen and some paper... Fill up the tank. Reset the trip meter. Drive. Next time you fill up, record the miles on the trip meter. Record how much fuel you put in the tank, filling it. Try to be consistent (ie. when the pump shuts off, do not keep topping it off to the next full dollar). Divide the number of miles driven between fill ups by the gallons pumped to fill the tank. There is your actual calculated mileage.
Keep a running tally to get more accurate results.
Old 10-13-2008, 05:45 AM
mysons95's Avatar
mysons95 is an unknown quantity at this point
I believe that truck holds 17 gallons. Mine holds close to that.
swartlkk gave a good description of mpg.
And yes, do this several times to get an average.
Trust me, when you are out mudding, you don't want to try and figure your gas mileage.
Old 10-13-2008, 09:25 AM
rriddle3's Avatar
The 2 dr version should have a 19 gallon tank, a 4 dr has an 18 gallon tank.
Vermilion
08-01-2007 07:52 PM
tammikm
14
01-28-2007 02:39 AM
getbent
11-21-2006 04:33 AM
tommyd
10-25-2006 01:10 AM
magnum434
Engine & Internal
13
08-17-2006 01:44 AM
Quick Reply: milage help?
