minor heat problem
Old Sep 26, 2009 | 06:43 PM
willum98e's Avatar
willum98e is an unknown quantity at this point
Default minor heat problem
annoying problem. after my 2004 blazer really warms up I get warm air from the floor vents (heat turned off) if I turn the fan on. dealer says this is normal. am I the only one experiencing this? on a mild day, 75 degrees, I need a/c after a while to keep my feet cool.
Old Sep 26, 2009 | 08:27 PM
Ryanmatt135's Avatar
Ryanmatt135 is an unknown quantity at this point
yea, i get this. especially on the passenger side. i believe that its due to a lack of insulation between the heater core and kick panel.you could try pulling out your lower dash kick panels and attach insulation material to the inner side of the kick pannels, that should cut down on the heat. - you can buy the insulation at almost any parts store or from summit or jegs.
http://www.koolmat.com/main.htm
Old Sep 26, 2009 | 09:19 PM
Nathan1991's Avatar
Nathan1991 is on a distinguished road
Ya i get this too, but out of the top vents as well (fan turned off)
Old Sep 27, 2009 | 09:39 PM
oisinirish's Avatar
Could be a couple of things. The flapper that directs air to the floor vents may not be closing. Or you can try pushing the recirc button on the HVAC controls which shuts off air coming in from the outside. The newer vehicles are constantly on "vent" without this button pressed. It does "not" work if the defroster is on though.
rabbit0102030
Apr 20, 2020 06:51 AM
RGrandmason
Jul 13, 2011 12:32 PM
stevo
May 7, 2009 02:46 PM
flowmasta
Aug 23, 2006 12:22 PM
94TahoeLT
Jun 4, 2006 03:56 AM
