Misses Only When Cold????
Old Sep 29, 2009 | 04:19 PM
reelbroke2's Avatar
reelbroke2 is on a distinguished road
Jason Rebellion...on my 95 i have 2 coolant sensors..left head is the engine temp sensor (light grey plug end)and in the front of the intake is the coolant temp sensor (black plug end)..hope that helps
Old Sep 29, 2009 | 07:17 PM
Jason Rebellion's Avatar
Jason Rebellion is on a distinguished road
Originally Posted by chevycrazy3690
ok so i took off mt EGR and gave it a good cleaning. . . still nuthin. then i unplugged my MAP sensor and it ran fine jus a littlt harder when shifting. so should i get a new MAP sensor or should i look at the distributer.
keep us posted so I'll know what to fix on mine! thanks a lot
Old Sep 29, 2009 | 11:44 PM
TipOTexas's Avatar
TipOTexas is on a distinguished road
I have the same problem in my 2000 four door. It has been suggested to me that it might be the Idle control valve. I just ordered one and will post up with the results once installed in a few days. Any body tried this already?
Old Sep 30, 2009 | 06:07 AM
on the morning miss the idle is fine, it stumbles when you take off in it
Old Sep 30, 2009 | 06:27 AM
hamlakid's Avatar
hamlakid is on a distinguished road
Default morning miss
Same here!!
Old Sep 30, 2009 | 11:38 AM
claughlin89's Avatar
claughlin89 is on a distinguished road
guys i have changed the iac, cap n rotor, wires, tps, mas, and ignition module.........no change. im out of ideas.
Old Sep 30, 2009 | 11:43 AM
Have you tested the wiring to see if you have a broken or otherwise compromised wire that is causing intermittent dropouts/spikes in signals necessary to the proper operation of the motor (TPS, IAC, MAF, MAP, ICM, coil, CMP, CKP, etc)?
Old Sep 30, 2009 | 04:36 PM
hamlakid's Avatar
Hey guys………this Monday evening I stopped for a fill up. I have always used regular gas in my blazer. With all the things I’ve tried to get rid of this morning miss and nothing worked so far. I decided to try a tank of plus grade to see if it would make a difference. The next morning I had my lawn mower on my trailer hooked to the blazer and the outside temperature was about 15 degrees cooler than it’s been all summer. So I figured this would be a good test. It started up, pulled out of my drive and it did not miss. Not even one time. So now, I didn’t know if it was because it was under a load pulling the trailer or the plus fuel that I was using... This morning it was even cooler than yesterday, so with out the trailer behind it, I started it up and it went down the road like a new blazer. I’ve got my fingers crossed because this is the first time I was able to take off with out the morning miss in over 6 months. Worth a try!!
Old Sep 30, 2009 | 04:42 PM
i might just have to try that
Old Sep 30, 2009 | 07:35 PM
It is possible that you have a lot of carbon built up in the combustion chamber... Premium fuel will resist predetonation better than regular or mid-grade. A few seafoam treatments (down the throttle body) may help clear up this condition if it exists.
