Multiple issues with 2000 blazer
Old May 25, 2016 | 12:42 PM
Racer_X's Avatar
Racer_X is on a distinguished road
The parts on Amazon are much cheaper than at Advance auto or Rockauto.com. I disconnected and checked all of my plug wires yesterday afterwork and they all seem to be fine. I reconnected them all and made sure they were on tight. Then I went to the store and came home and the check engine light went off. I also drove to work this morning and it has been fine since. The wires do look rather old though so I think I may change them out.
I don't know about Advance. I buy oil and fluids there sometimes and recycle my old oil there, but usually don't buy parts there.
For RockAuto, here's the prices I found:
AC-Delco parts:
  • 9746KK, $42.79, with discount, $40.65
  • D465, $7.86, with discount $7.47
  • D328A, $24.99, with discount $23.74
  • 41-993, $5.22, with discount $4.96
Total for 6 plugs, wires, distributor cap and rotor, plus shipping to ZIP Code 17327 (from your info here), $106.60. All parts were in one warehouse (you do have to be careful about that at rockauto).
PM me here if you need a discount code.
Be sure to put some dielectric grease in those boots when you put them on.
Old May 26, 2016 | 06:41 AM
Tajohns34's Avatar
It actually works out to be about $13 more from Amazon. However I have prime so I get in 2 days instead of about a week. I also have a bunch of points so I get money off. I ordered the wires and I should have them today. It was fine for 2 days and now it is misfiring like crazy again. So it is getting new plug wires this weekend.
Also I went to https://blazerforum.com/forum/diagnostic-trouble-codes-dtcs-49/p0410-explained-35146/ but the pictures aren't loading.
Old May 26, 2016 | 02:57 PM
Loading the images must be something on your end, they load fine on my PC and mobile P0410 has 11 pages of diagnostics in the flow chart, not a fun DTC to troubleshoot. Worse than some of the EVAP flow charts Take your time, don't skip any steps, and you'll do fine.
Old May 26, 2016 | 05:42 PM
Tajohns34's Avatar
Apparently they don't like firefox. The opened up fine on my home PC with Microsoft Edge.
In other news, I decided to do my plug wires today. The old ones were very hard and brittle. The new ACDelco ones were much nicer than the ones that were on there. I couldn't find a brand anywhere on them. cylinders 4 & 6 wires broke coming out.
Wire to cylinder 4
Wire to cylinder 6
Attached Thumbnails Multiple issues with 2000 blazer-20160526_175826_zpszjqh5vn9.jpg   Multiple issues with 2000 blazer-20160526_175818_zpsdkmhx64r.jpg
Old May 31, 2016 | 07:37 AM
Tajohns34's Avatar
So I did my plugs on Thursday and It has been running pretty good since then. Which makes sense since the plug wires were in pretty bad shape.
Old Jun 2, 2016 | 08:15 AM
Tajohns34's Avatar
I decided to do a visual inspection of my Secondary air system and everything seems in tact at least. When I checked the vacuum lines I found this valve in there. At first I though it was a normal vacuum coupling but it has a spring and ball in it almost like some sort of check valve. Does anyone know what this is?
Also my P0410 code has been showing as a pending fault for several days now. My other codes that I resolved were showing as just regular faults.
Attached Thumbnails Multiple issues with 2000 blazer-image1_zpsmiopcmd4.jpg   Multiple issues with 2000 blazer-image3_zpsj5eji1so.jpg   Multiple issues with 2000 blazer-image2_zpslyev5y3c.jpg
Old Jun 2, 2016 | 01:41 PM
Racer_X's Avatar
Was that in the little vacuum line that goes back between the booster and the firewall?
That's a check valve. If it's in that little vacuum line, that's the part that keeps the HVAC system from switching to defrost when you take off hard or go up a hill.
Old Jun 3, 2016 | 04:46 AM
Tajohns34's Avatar
That valve goes in the vacuum line that goes to the secondary air injection.
Old Jun 9, 2016 | 03:06 PM
Tajohns34's Avatar
Looked under the car yesterday because the PO440 code is still present. Looks like when I had my leaf springs replaced they didn't put one of teh clamps back on the charcoal canister, and I smell gas when I get close to the canister.
Attached Thumbnails Multiple issues with 2000 blazer-20160608_161548_zpsphh36ece.jpg
Old Jul 8, 2016 | 09:17 AM
Tajohns34's Avatar
So far I have fixed the first issue by replacing the old no name spark plug wires with ACDelco wires. I fixed the third by putting a loose hose clamp back in place on the charcoal canister and putting on a new gas cap. The airbag issue, I need to pull the carpet up and make sure the connector is tight. The P0410 issue is interesting. I decided to pull one of the lower hoses off to the pump and a pretty significant amount of water ran out. So I got a pump, valves and the injection valve from a junk yard. As soon as I can get the valves to break loose from the exhaust manifolds I will replace all the parts to see if the light goes off.
