Multiple questions....95 Blazer 4wd 4dr
Old Oct 13, 2010 | 01:35 PM
dougg01's Avatar
dougg01 is on a distinguished road
Default Multiple questions....95 Blazer 4wd 4dr
So, my build of the 2000 Jimmy is over - ended with a bent frame. All the driveline is good except the motor (which might be, but i need to check it). Lots of new parts need to move to another platform.
Enter 1995 Blazer, 4wd 4dr. Good shape. Works good. Needs some TLC. Lower miles. Good.
Can I swap my 2000 disc brake rear over to the 95 without issue...? What else might I need to change...? ABS module..? Master Cylinder...?
Are the front calipers the same so I can swap all that new stuff over...?
What about front CVs, hubs and all that...? Will they swap...? All my junk is NEW on the Jimmy and still fine.
The 95 has the CPFI motor and my 2000 has the MPFI stuff. Any thing new I need to know about that one over the junk I've already done with the newer ones (pres reg, spider leaks, etc)...?
Does the front axle actuator work the same...?
It would be nice if I could swap everything over. Make a nice rig.
Thanks.
Old Oct 13, 2010 | 01:45 PM
robertr728's Avatar
robertr728 is on a distinguished road
If i wanna know if parts are interchangeable i go to a auto parts web site like rock auto or auto zone. Get the part #s for both years in question and if they match they are interchangeable. You do your home work to see if the stuff you wanna swap will work.
LS178bu
Jan 11, 2014 12:48 PM
daddyx2
May 29, 2012 05:44 PM
Jonboy
Mar 12, 2012 07:08 PM
tcrouch1606
Jan 29, 2010 06:16 PM
OI5HI
Dec 24, 2009 11:16 PM
