my blazer will turn over but not crank
Old Sep 18, 2012 | 08:28 AM
rjnms2010's Avatar
rjnms2010 is an unknown quantity at this point
Default my blazer will turn over but not crank
We have changed fuel filter and the sensor and it is getting fire. It is getting fuel to the bleeder valve but no fuel is going into the intake bowl. Can anyone give me some ideas?
I am being told it is probably the injecters but could someone tell me what they think.
Old Sep 18, 2012 | 12:16 PM
spittybays
Guest
Posts: n/a
Old Sep 20, 2012 | 03:42 PM
kf7lcw's Avatar
kf7lcw is on a distinguished road
Year? Put a test lamp on the injector and have somebody crank while you watch, if you're getting light (flashing), but no spray, injector. If you're getting no light, something in the electrical is wrong most likely. If you're getting spray, its probably a spark issue.
Old Sep 23, 2012 | 12:28 PM
rjnms2010's Avatar
It is a 97 4x4
Old Sep 24, 2012 | 09:25 PM
xgiovannix12's Avatar
Start by checking the fuel pressure. Follow the link Spitty gave you.
Old Sep 25, 2012 | 03:43 PM
kf7lcw's Avatar
If you have good pressure take off the air filter cover and have someone open the throttle while you look down the throttle body (don't put your head right over it, backfires are always possible), and see if the injectors are spraying (I think you can see it on a 97?). If they are not but you have a good pressure, I would do as I suggested and backprobe the injectors with a light, have somebody crank. You likely won't get any flashing, if you do its definitely injectors.
If you don't, I'd look to the crank position sensor.
Old Sep 25, 2012 | 03:44 PM
kf7lcw's Avatar
P.S. if you don't have pressure, look to the pump. If you have spray but no run look to the ignition.
djd99
Aug 9, 2018 09:50 PM
Buddykitchen
Dec 10, 2016 06:37 PM
drummerdude84
Jan 7, 2011 01:18 PM
j79302j
Aug 31, 2010 09:02 PM
greeneyes1975
Jul 11, 2010 02:37 PM
