1998/Engine will turn over but not start
Old Jul 9, 2010 | 02:55 PM
greeneyes1975's Avatar
greeneyes1975 is on a distinguished road
Default 1998/Engine will turn over but not start
I have a 1998 Blazer and the engine will turn over but will not start. Getting fuel and spark from the spark plugs but it just will not start. Someone mentioned it may be the ignition switch and I was wondering if anyone had any experience with this? Does it make sense?
Old Jul 10, 2010 | 09:40 AM
taba5's Avatar
taba5 is on a distinguished road
just a few weeks ago my buddy went through this with his 98 Bravada... it just wouldnt start but it would def. crank
come to find out it was the distributor cap and rotor, id start with that for sure...
another preliminary check is to pop the gascap for a few seconds and then put it back on and turn the key to on and listen for the fuel pump to cycle.
also clean the Mass Ait Flow unit (if equipped with an oil type air filter the heated element could get gunked up and cause a no start)
Old Jul 10, 2010 | 11:01 AM
reytx1's Avatar
reytx1 is on a distinguished road
I would def. check the cap and rotor.
When was the last spark plug change?
My blazer would not start one day so I did a spark plug change and I had two broken spark plugs
I swapped them out and it started up beautifully
Old Jul 11, 2010 | 02:37 PM
Well after a week in the shop and $300 later it was apparently a broken wheel or something inside the ignition?? Thanks for the advice!!
1998mom
Aug 23, 2013 08:22 PM
krazykracker
Feb 2, 2013 12:44 PM
rjnms2010
Sep 25, 2012 03:44 PM
leebnc
Oct 16, 2010 02:26 AM
j79302j
Aug 31, 2010 09:02 PM
