turn over but not start
Old Aug 31, 2010 | 11:48 AM
j79302j's Avatar
j79302j is on a distinguished road
Default turn over but not start
I have a 01 blazer, I don't know what to try next. It will turn over but not start. Sometimes it has spark but not all the time. Sometimes I can turn the key one click and the motor will turn over a little. I have replaced the crank sensor, the sensor in my distributor, ignition control module, and coil. I was told that it could be the ignition switch. Thanks for any help.
Old Aug 31, 2010 | 07:07 PM
1998MSO's Avatar
1998MSO is on a distinguished road
You should diagnose using the 98+ No Start article listed in the forum, it's very helpful. Also, use the search feature to find the many similar posts.
Old Aug 31, 2010 | 08:37 PM
j79302j's Avatar
I looked over that. I had a crank sensor code replaced that. and many other parts. Sometimes it has a spark for a few seconds most of the time it doesnt. The motor will turn over a little bit when i turn my key one click. it never did that before. i have replaced almost everything except the computer, and ignition switch.
Old Aug 31, 2010 | 08:43 PM
Did you test the wiring from the CKP to the PCM?
Old Aug 31, 2010 | 08:45 PM
j79302j's Avatar
i dont know what those are?
Old Aug 31, 2010 | 08:48 PM
As can be found with a quick search:
CKP==crankshaft position
PCM==powertrain control module
You can also search for the specific code you received that led to the replacement of the CKP sensor. Many of the codes are posted in the OBD2 code area within the Tech Article (DIY) section and the code sheets show a wiring diagram.
Old Aug 31, 2010 | 09:00 PM
j79302j's Avatar
no i havent tested that. is that what is under my steering wheel?
Old Aug 31, 2010 | 09:02 PM
No. You said you replaced the CKP sensor already... The PCM is located on the passenger side fender sitting on top of the coolant over flow tank.
krazykracker
Feb 2, 2013 12:44 PM
rjnms2010
Sep 25, 2012 03:44 PM
leebnc
Oct 16, 2010 02:26 AM
greeneyes1975
Jul 11, 2010 02:37 PM
TourRider
Jan 7, 2008 11:17 AM
