Mysterious noise from front end, sounds like passenger side
Old Jul 20, 2015 | 05:30 AM
Bigjoe1986's Avatar
Bigjoe1986 is on a distinguished road
Just replaced wheel bearing Saturday and everything seemed great until I started getting that damn noise again yesterday. Engaging my 4x4 will stop it immediately but is only a temporary fix.
I would like to figure out what the cause is to get it repaired in case it is doing other damage which is more expensive.
Old Jul 20, 2015 | 07:33 AM
Check the Tech Article link in my signature and look for a post titled something like "Clicks in 2wd, goes away in 4wd".
Old Jul 20, 2015 | 07:56 AM
If you have the NV233 transfer case, (3 button dash switch), the vacuum switch on the transfer case is leaking internally. 20 minute, cheap fix. GM latest and greatest updated part number is: 89059420. Dorman has a less expensive version available at most auto parts stores for under $20. Dorman - Help Transfer Case Switch 49315: Advance Auto Parts
Old Oct 18, 2015 | 11:43 AM
Bigjoe1986's Avatar
I know this thread has been dead for a while now but I think I finally figured out the noise was coming from my starter.
The wire rotted off my starter a few weeks ago and once replaced I haven't heard the noise since.
I replaced both hub bearings and vacuum switch and had a friend of mine check it over after hearing it himself and he was clueless, my best guess is the starter wasn't fully disengaging and power wire may have been arcing or something pushing it against the flywheel, as for it stopping when I put it in 4x4 I have no idea how that had any effect but it worked..
Figured id post my findings to try and help anyone else
Old Oct 18, 2015 | 12:13 PM
CWBDDSPC's Avatar
CWBDDSPC is on a distinguished road
Thanks for the update!!
Nice work too
Old Nov 7, 2015 | 10:29 PM
chevyragtopguy's Avatar
chevyragtopguy is on a distinguished road
Do hub bearings cause a thumpy feel, like a flat spot on the tire?
Old Nov 8, 2015 | 05:25 PM
WalkGood's Avatar
WalkGood is on a distinguished road
Originally Posted by Bigjoe1986
I took a sound clip with my phone but the file is too big to upload here and I have no idea how to shorten it if I can. If anyone has any ideas how I could make that accessible I'm all for it if it helps figure out the problem
Upload to youtube, set to public and post link here.
Old Nov 9, 2015 | 03:14 AM
Toocute350's Avatar
Toocute350 is on a distinguished road
Sounds like a failed bearing.It`s important to keep these bad boys greased atleast once a year.When it comes to having a 4x4 model..Mud,sand and dirt are the main reason`s bearings fail.
Old Nov 10, 2015 | 08:52 AM
Tajohns34's Avatar
I have never experienced that.
Old Nov 10, 2015 | 12:02 PM
CWBDDSPC's Avatar
I think the 4WD hub assembly is non servicable
