Need to Do Brake Job on 01 Blazer
Old Jan 22, 2007 | 09:20 PM
bmxracer182's Avatar
bmxracer182 is an unknown quantity at this point
Default Need to Do Brake Job on 01 Blazer
I need to do a brake job on my 2001 blazer 2wd. Can anyone help me with an online DIY that will show me how to do it on this car. Also, can anyone help me with a list of things I will need.
Thanks...
Old Jan 22, 2007 | 10:53 PM
Hanr3's Avatar
Default RE: Need to Do Brake Job on 01 Blazer
Hanyes manual from your local autoparts store, and I believe Autozone has the instructions on-line.
Things you will need.
Brake shoes (would help to know if this is the fronts or backs).
Rotors.
Brake cleaner.
Brake compression tool.
Jack and jack stand.
torque wrench.
Basic hand tools to remove the caliper, and caliper bracket.
Brake grease.
Anti-Seize.
Couple rags.
and a couple brewskies.
Old Jan 23, 2007 | 05:57 AM
Chevy Lover's Avatar
Welcome to the forum.
A little more info would help, like front or rear, disc or drum.
Old Jan 23, 2007 | 09:45 AM
blazinloud's Avatar
i tend to skip it all and go right to the brews......after that i cant even remember what i was going to fix....works for me.....
Old Jan 23, 2007 | 05:44 PM
pilgrim's Avatar
pilgrim is an unknown quantity at this point
Take apart only ONE brake at a time. At some point during the job, you will need to check the assembly on the other side of the car to confirm that you are putting things in the right places. This is especially truw with drum brakes.
And yes, get a shop manual and read it before starting.
Old Jan 23, 2007 | 09:10 PM
woodsballr's Avatar
woodsballr is an unknown quantity at this point
as far as a brake compression tool goes i just use a 2x4 and c-clamp, if you tighten it down all the way before putting the caliper on it works just fine. at least as far as front brakes goes, not sure bout backs, never done them before.
Old Jan 23, 2007 | 11:54 PM
Hanr3's Avatar
I believe the brake compression tool is cheaper then the c-clamp.
http://s7.sears.com/is/image/Sears/00947365000
$10 at Sears.
Old Jan 23, 2007 | 11:58 PM
Yeah, but a C-Clamp has so many other uses! LOL.
Old Jan 24, 2007 | 12:16 AM
Hanr3's Avatar
lol
[sm=alcoholic.gif][sm=hail.gif]
Old Jan 24, 2007 | 01:49 AM
woodsballr's Avatar
the c-clamp may be more expensive but i already have one so it didnt really cost anything. if you dont have one go for the cheaper i say.
kiwiblazer
Jun 19, 2010 03:00 AM
republic
May 16, 2010 10:39 PM
Trevj
Apr 23, 2010 11:36 AM
armydad71
Nov 20, 2009 09:22 AM
mikeinwi
Jan 24, 2009 02:00 AM
