Need help with ABS Control Module
Chevy Blazer 2002
While driving the ABS indicator lights on. Diagnoses revealed problems with ABS Control Module. Replacement or repair? Your experience...
Of course the replacement is the easier way but $$$ . How about repair?
What trouble code did the diagnostic show? A very common reason for the ABS light coming on is failure of one of the front wheel sensors. Another problem (which I have experienced myself) is when a front hub bearing goes bad & upsets the air gap between the ABS sensor & the toothed pulse ring in the hub itself.
Thank you for interesting information but I am not sure I can do that herself))
So I found guys in Van Nuys who really helped me. I read a lot of reviews online about these services and I must say the customers had very good experience. Following the advice I got in touch with guys from Module Repair Pro Inc. They are from Van Nuys CA. tested the module on a special test stand and repaired with upgraded components . Good quality and reasonable price.
If you are interested I can give you more information
Module Repair Pro INC
5911 Lemona Ave Van nuys CA 91411 Phone (818)235-1095
