Need help idenifing and locating replacement part!!!
Old Sep 19, 2015 | 08:27 PM
PhantomZ's Avatar
PhantomZ is on a distinguished road
Default Need help idenifing and locating replacement part!!!
Hello all I've been trying to locate a replacement part for a 95 chevy blazer 4x4 door.it I attached a picture. But to be honest I'm not entirely sure what it's called. I've found it called lower mode door vacuum actuator or blend actuator and a couple other names so I've been trying to find a replacement online cause none of the auto part shops around carry it or can even find anything like it. Any help would be appreciated.
Attached Thumbnails Need help idenifing and locating replacement part!!!-20150919_181347.jpg   Need help idenifing and locating replacement part!!!-20150919_181356.jpg   Need help idenifing and locating replacement part!!!-20150919_181531.jpg
Old Sep 19, 2015 | 08:39 PM
PhantomZ's Avatar
Ok after searching almost all day I found it.. it's called Instument panel actuator part # 1996794. if anybody needs the info.
Instrument Panel Actuator - 1996794
Old Sep 19, 2015 | 09:15 PM
It's either the mode valve actuator, or the heat/defrost valve actuator. They are very similar in appearance and function, and they are the only two actuators with two vacuum lines, the rest of the HVAC actuators only have one. The colors of the vacuum lines that attach to it will determine which actuator it is.
Dyspayre
Dec 25, 2013 05:10 AM
splat55
Nov 25, 2011 08:42 PM
radiorara
Jun 21, 2011 07:39 AM
avorg
Oct 10, 2007 09:58 PM
777777BLUE
May 23, 2006 10:44 PM
