NEED HELP, rear brakes engaged after pad change
Old Aug 16, 2005 | 01:27 PM
LoLoS10Blazer87's Avatar
LoLoS10Blazer87 is an unknown quantity at this point
Default RE: STUMPED!!! rear brakes engaged after pad change
Yeah after a while, the inside of the hose can deteriorate and will allow fluid into the caliper, but won't let it back out, that could explain why the brakes are still tight...
Old Aug 17, 2005 | 01:04 PM
dbo98's Avatar
dbo98 is an unknown quantity at this point
should i be able to see that just looking?
Old Aug 17, 2005 | 01:08 PM
m00nwater's Avatar
m00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond reputem00nwater has a reputation beyond repute
mine went on my Volvo when I had it and it was very obvious that the hoses were cracked
Old Aug 17, 2005 | 08:28 PM
dbo98's Avatar
hey, i went for another ride today and made a couple more observations. (1)when im sitting still at a stop light if i press firmly on the pedal it will slowly go all the way to the floor. (2) when i do that it seems to free the brakes up some when i take off, but as soon as i touch the pedal again i can feel the drag start over all again.(3)after i got home i sat in the driveway pressing the pedal all the way to the floor and then releasing it trying to get a feel for how much they were draggin, and the pedal stuck to the floor 3 or 4 times and i had to put my foot under the pedal and pull it back out, making a distinct popping sould each time i released it like the rod for the booster was binding the pedal up. so with the breaks sticking, going to the floor with steady pressing and hanging up at the bottom could i be looking at the booster as my problem ?
Old Aug 23, 2005 | 11:02 AM
That's very possible
Did you check for leaks around the master cylinder?
Old Aug 23, 2005 | 11:28 AM
dbo98's Avatar
ok, here we go. i have another master cyl. on the way just in case. heres what we have. i have the rear end on jack stands and when i put the thing in nuetral i cant turn the rear wheels. when i put it in gear they wont turn until i hit the accel. but ,if i press the brakes at one certain pont in the travel of the pedal the wheels will start to roll. if i hold the pedal at that 1 point they will cont. to spin, but as soon as i relase the pedal they stop again.
Old Aug 23, 2005 | 10:51 PM
dbo98's Avatar
all right, i broke down and bought 2 calipers today and put them on. it fixed my brake dragging prob. but when i bled the system the rears didnt have as much pressure on the fluid as the front, the pedal didnt firm up as much as i think it should have and the brake light in the dash is now on.
poertsch
Apr 23, 2016 01:05 PM
Kaffeene
Sep 23, 2012 12:00 AM
XTREME POS
May 29, 2008 09:05 PM
Blindthieves
Oct 28, 2007 06:35 PM
kuzushi
Feb 3, 2007 07:48 PM
