NEED HELP......WONT START....just tuned it up
Hey guys, i just did the following things and now my 2004 wont start......new serp belt, pulley tentioner, thermostat, temp sensor, coolant flush. it cranks like its trying to start but wont roll over. the belt is routed correctly, all sensors and vac lines are plugged back in. any ideas? please help!!!!
yes, worked fine before, now nothing. i went back and double and triple checked every harness, wiring, vacuums, etc. i did take the air intake system off and back on, but everything is back in place as it was before. i have no clue whats wrong with it and i am very engine literate, so this makes no sense to me.
i had spark. pulled a plug and it was soaked with gas. so i unplugged the fuel pump relay, cranked it and it started. let it run & burn off what was in the cylinders until it cut off/ran out of fuel. plugged the relay back in and it started back up fine. let it sit for 20 minutes, went to crank it again and it wouldnt start again. i had to push the gas petal to the floor while cranking and it started up. let it idle for 5 minutes and it was fine, but spitting black fluid crap out of the tailpipe. drove it around for a little bit, and it ran ok but the idle was sticking agound 1500 rpms.
any idea why it didnt wanna start after i cleared it out? what was the black crap? what woulda caused the idle to stick like that? leaky injector? need to clean the throttle body and related parts?
did you check afterwards if your cylinders were soaked with fuel afterwards? If so, you probably have a fuel leak which is flooding your engine preventing it from starting it. The black stuff might be the fuel that was in the engine and it turned black while it went through the headers, cat, muffler, etc.
Microman
06-01-2015 01:46 PM
bobby099
15
11-07-2012 07:29 PM
