need a lil help my belt on my truck
![Question](https://blazerforum.com/forum/images/icons/icon5.gif)
well i have a 2000 s10 blazer my belt is make noise and i dont know what to do the belt is new and it only makes the noise when i hit the gas. i think i may be one of my pulleys but don't know any help would be nice thank u
*Moved to 2nd Gen Tech*
What was the brand of belt that you installed? I have used Goodyear Gatorback belts with great success on the s-series vehicles. I have had many other brands of belts do the same thing as you describe even when new.
am not to sure but i know its don't good yr so u dont think its the pulley
get a dinner candle and dress the belt on each side, DONT DO IT BY PULLIES, if you slip your new belt may bite it, find at least 4 inches of belt and press the candle down on one side, then the ribbed side. cheap and it works.
http://www.youtube.com/watch?v=I0-ltd8vS8Q
hey thanks man it work so far
Although you can try the candle trick, swartlkk is right. I had a squeak in my '00 Jimmy. I thought it was the idler pulley. Still had the squeak. Got a Goodyear Gatorback belt and that solved it!
ok cool i am just get a good yr if it does it again do u know around what it cost
It's the tensioner you need to replace.... if it's bouncing around a lot at idle then it's bad. they are like $25.
I usually get 2 tensioners per belt life.
You should never have to add "conditioners" or an other home remedy to quite a belt.
While I've never had a tensioner go bad,I must agree with dg98adams:NEVER "condition" a belt,one is only chasing the symptom,not the problem!
A belt needs to be DRY DRY DRY to function effectively!
lionel2
09-07-2012 02:45 PM
abig84
12-31-2009 05:40 PM
travisrussell88
09-13-2008 08:50 PM
