Need some help... - Washer Fluid Pump
Well, I went to the parts store this morning to get a washer fluid pump for the front... Thought it would be an easy fix... Guess not, there is no voltage going to the front pump ... Does anyone have a wiring diagram that shows where the front connector goes to? I don't really want to rip everything apart without knowing where I'm going to check...
Thanks in advance...
BTW
Just bought it used so IDK how long it has been broken.
2001 Blazer
4.3 V6
Mike George
BTW
2001 Blazer
4.3 V6
Mike George
*Moved to '2nd Gen Tech'. Please read the section description before posting a thread in it. The 'New member' section is only for introducing yourself and your vehicle.*
sorry... thought I could only post in the new member area.
I have the same problem
have you checked for a short to ground?
There are two pumps in the reservoir: front and rear. Make sure you're checking the right one.
I fixed it a little while ago... I just took out the whole reservoir and got to the connector for the front washer pump, made sure the connection was good and then it worked.
Cool, thanks for posting back.
carlo
01-01-2007 03:03 PM
kaindragoon36
03-25-2006 04:22 PM
fruccoman
02-15-2006 07:08 PM
